29348 Discussions
error LNK2019 and fatal error LNK1120
camiel
Hi
I have a Fortran code and I use Visual Studio 2005 to run it.
Until today, it was working fine. I made some basicmodifications and now I have this two errors:
Error1 error LNK2019: unresolved external symbol _E referenced in function _MAIN__Modelos Lineales
Error2 fatal error LNK1120: 1 unresolved externalsModelos Lineales
I don't know what is the problem, please help me.
thanks
The most common cause for this problem, based on your description, is that you have a reference such as:
X = E(3)
where you intend E to be an array but it is not declared as one, so the compiler thinks it's an external function. If this is the case, you need to declare E as an array. Sometimes, if you are using fixed-form source (.f or .for file type) and you add characters to a declaration, you can push things past column 72 and this can create puzzling errors.
Try adding IMPLICIT NONE or compile with /warn:decl and see if that shows you the problem.
camiel
Thank you very much, Steve.
My program it's working now.
shub
Hi Steve,
I am using Visual Studio 2008. I am getting similar errors after building my fortran code as camiel-
1>cjw.obj : error LNK2019: unresolved external symbol _UPSTRM referenced in function _MAIN__
1>Debug\cjwave.exe : fatal error LNK1120: 1 unresolved externals
In your last post, you suggested camiel to " compile with /warn:decl". Could you please tell how to implement that in VS 2008; Camiel was using VS 2005.
Right click on the project and select Properties. Go to Fortran > Diagnostics. Under Language Usage Warnings, set "Warn for Undeclared Symbols" to Yes.
This may result in many compile-time errors if you rely on implicit declarations. It also won't help if you CALL UPSTRM. I suggest you search your source to see what UPSTRM is supposed to be, and where it is used.
shub
Thanks steve.
