29486 Discussions
error LNK2019: unresolved external symbol _GETCWD@8 referenced in function _
Ashley_Weinstein
I have some code that I was able to debug through two weeks ago but now when I attempt to compile and link I get the following error messages below.
Why would this compile in Release mode but not Debug mode? I've run through the solution/project options with no luck.
Any help figuring this out is appreciated!!! Thanks =)
Build Log
Build started: Project: RSISPYEXE, Configuration: Debug|Win32
Output
Compiling with Intel Visual Fortran Compiler XE 12.1.1.258 [IA-32]...
ifort /nologo /debug:full /Od /warn:interfaces /iface:cvf /module:"Debug\\" /object:"Debug\\" /Fd"Debugvc90.pdb" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc9 /Qlocation,link,"c:Program FilesMicrosoft Visual Studio 9.0VC\\bin" "K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSIDECNFG.f90"
K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSIDECNFG.f90(173): warning #6371: A jump into a block from outside the block may have occurred.   [25]
            GOTO 25
K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSIDECNFG.f90(192): warning #6371: A jump into a block from outside the block may have occurred.   [26]
            GOTO 26
ifort /nologo /debug:full /Od /warn:interfaces /iface:cvf /module:"Debug\\" /object:"Debug\\" /Fd"Debugvc90.pdb" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc9 /Qlocation,link,"c:Program FilesMicrosoft Visual Studio 9.0VC\\bin" "K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSISPY.f90"
K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSISPY.f90(433): warning #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute. Required explicit interface is missing from original source.   [INPUTDATL]
    CALL RSIDECNFG(FNam1,InputDatL,NumReadI)    !Pass *.rsi file to decryption subroutine. Receive back original *.dat text line by line and # lines.
Linking...
Link /OUT:"DebugRSISPYEXE.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEDebugRSISPYEXE.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEDebugRSISPYEXE.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEDebugRSISPYEXE.lib" "DebugRSIDECNFG.obj" "DebugRSISPY.obj"
Link: executing 'link'
RSIDECNFG.obj : error LNK2019: unresolved external symbol _GETCWD@8 referenced in function _RSIDECNFG
DebugRSISPYEXE.exe : fatal error LNK1120: 1 unresolved externals
RSISPYEXE - 2 error(s), 3 warning(s)
Build Log
Build started: Project: RSISPYEXE, Configuration: Release|Win32
Output
ifort /nologo /module:"Release\\" /object:"Release\\" /Fd"Releasevc90.pdb" /libs:static /threads /c /Qvc9 /Qlocation,link,"c:Program FilesMicrosoft Visual Studio 9.0VC\\bin" "K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSIDECNFG.f90"
            GOTO 25
            GOTO 26
ifort /nologo /module:"Release\\" /object:"Release\\" /Fd"Releasevc90.pdb" /libs:static /threads /c /Qvc9 /Qlocation,link,"c:Program FilesMicrosoft Visual Studio 9.0VC\\bin" "K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXERSISPY.f90"
Linking...
Link /OUT:"ReleaseRSISPYEXE.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEReleaseRSISPYEXE.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /SUBSYSTEM:CONSOLE /IMPLIB:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEReleaseRSISPYEXE.lib" "ReleaseRSIDECNFG.obj" "ReleaseRSISPY.obj"
Embedding manifest...
mt.exe /nologo /outputresource:"K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEReleaseRSISPYEXE.exe;#1" /manifest "K:PyrotecSoftwareRSISimcon930680IVFRSIIOFACEEXERSISPYEXEReleaseRSISPYEXE.exe.intermediate.manifest"
RSISPYEXE - 0 error(s), 2 warning(s)
Debug
FORTRAN
LINKER
Release
FORTRAN
LINKER
You have /iface:cvf set for Debug, not Release. Take it out of Debug. This is under Fortran > External Procedures.
Ashley_Weinstein
Thank you so much!!! I don't remember flagging this option for Debug since then but I must have.
One more question: when I incorporate this code into some legacy code (or vice versa), I'll be using RSISPY.f90 as the routine that will interface with a 3rd party executable (say Excel). So I'll be needing to use the '!DEC$ ATTRIBUTES DLLEXPORT ::' calling procedure.
Will I need to add any additional modifiers to the calling procedure like STDCALL?
If your code will be called from Excel, then yes, you will need STDCALL and probably REFERENCE and ALIAS as well.
Ashley_Weinstein
Thanks Steve! I'll find out what works when the time comes.
