error PRJ0019
Roe_Z_
Hello.
After compiling with the Qprof-gen and runing, I tried to compile with Qprof-use and got this error:
error PRJ0019: A tool returned an error code.
Do you know what this error is?
I'm using Visual Fortran Compiler XE 14.0.3.202 on windows server 2008 64bit.
Roy
Les_Neilson
Valued Contributor II
For me this message was always generated by the Microsoft manifest tool :  mt.exe
I found that by running the build process again it would be ok.
Les
This is a generic message Visual Studio gives when one of the tools it runs fails. As Les says, it is often mt.exe. Look at the build log to see if there is an indication there.
Roe_Z_
Hi Les and Steve,
Thanks for the reply.
Sadly, After cleaning the solutions, Rebuilding it with Qprof-gen, Runing and then rebuild it with the  Qprof-use tag, I'm still getting the same error.
The log did not revealed any indication except returning on the same error over and over.
Do you have any other isea (except try to uninstall fortran and install it again)?
Thanks!
andrew_4619
Did  you look at the build log file (BuildLog.htm)? This normally gives some information.
As others have said this is normally due to the manifest tool mt.exe and is often a problem of your antivirus program you can get your AV to exclude your development folders if this is the issue.
Roe_Z_
Hello guys.
Thanks for your replays.
After trying your solution and still  fail to compile, I uninstall and then reinstall the whole fortran Compiler XE.
It works now.
Thanks for your help.
Roy.
