29386 Discussions
error building netcdf-fortran in intel parallel studio xe 2016 update3
Fernando_M_3
Hi all, after build netcdf 4.4.1, i'm trying to build netcdf-fortran 4.4.4 (netcdf 4.4.1 is ok), with intel parallel studio xe 2016 update3, in rhel Enterprise Server 7.2.
'configure' and 'make' are ok, but 'make check' stops with:
ftst_rengrps.F(49): error #6404: This name does not have a type, and must have an explicit type.   [NF_NETCDF4]
      call check(nf_create(FILE_NAME, NF_NETCDF4, ncid))
compilation aborted for ftst_rengrps.F (code 1)
make[2]: *** [ftst_rengrps.o] Error 1
make[2]: Leaving directory `/root/libs/netcdf-fortran-4.4.4/nf_test'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/root/libs/netcdf-fortran-4.4.4/nf_test'
make: *** [check-recursive] Error 1
^C
[1]+  Exit 2                  make check &>check.log
Asked netcdf-support, and here is the answer:
Unfortunately I'm not familiar with intel parallel studio; it clearly looks like a compiler issue, but I don't have an environment where I can try to recreate this problem.
The Intel documentation provides some instructions for compiling netCDF-Fortran, found at the following address:
* https://software.intel.com/en-us/articles/performance-tools-for-software-developers-building-netcdf-with-the-intel-compilers
It may be able to provide some additional information that I lack.
I'm sorry I can't provide a more immediately useful or applicable answer, but hopefully this information will be helpful!
Have a great day,
-Ward
All log files are atthached
I´m stuck at this point and I hope your help make my day ;)
Thanks!!
