error code 144
solelabmec
Hi, I'm using abaqus 6.8.2 running a fortran subroutine with Intel Compiler 8.0 and the standard.exeaborted with system error code 144.
Can anybody tell me what this error mean?
Soledad
Can you show us the actual and complete text of the error messaage?
TimP
If I recall correctly, with ifort 8, the error message file had to be symlinked into the expected path, in order to display the full text message. 8.0 was not one of the better versions, although 8.1 still has adherents.
Tim, I'd think your comment would be applicable to Linux but not to Windows. The Windows compiler of that vintage had no separate message file.
A Fortran error 144 would be "Reserved Operand" which I don't think is possible in Intel Fortran. (That error code is historical, coming from VAX Fortran.) A Windows system error code of 144 is "DIR_NOT_ROOT: The directory is not a subdirectory of the root directory." This doesn't seem likely either.
