error code
Deleted_U_Intel
I repeatedly get the following error:
Error2HEV : error PRJ0019: A tool returned an error code
It is sometimes accompanied by a warning from a subroutine. I can get rid of it by "clean hev" but frequently it comes back after another compilation or two.
Thank you!
John
This is usually due to one of the non-compiler tools such as the resource compiler failing for some reason. Sometimes if you look at the build log, you'll see more, but I find that sometimes I need to run the commands from a command prompt to see exactly what the error is.
Ah, the manifest tool. We've seen this before but don't understand it. An easy workaround is to set the project property Linker > Manifest File > Generate Manifest File to No. You won't miss it.
