error creating a dll
kooka
im trying to create a DLL and when i build it it supposed to create a LIB import library, but i only see the dll file and other files like *.pdb, *.mod and *.obj. so i cant import it in my .exe file. Do you know what am i doing wrong?
This error means that you have not linked in the object or library that resulted from building module VARIABLES.
ZlamalJakub
New Contributor III
You are probably not exporting any routine from dll to be visible to your exe file. You must use
!DEC$ ATTRIBUTES DLLEXPORT::
subroutine ExportedFunction()
!DEC$ ATTRIBUTES DLLEXPORT:: ExportedFunction
return
end
Then routine ExportedFunction can be called from Your exe file and linker creates LIB file.
Jakub Zlamal
kooka
Quoting - kooka
thanks man, you are right it was the error. But now i have another problem. I can Build the librarys and run the .exe file in debug mode, but when i change to release mode when i try to buil the library i have an error like this:
Creating library Release/sysfunc.lib and object Release/sysfunc.exp
WRSLTS.OBJ : error LNK2001: unresolved external symbol _VARIABLES_mp_NELEM
Release/sysfunc.dll : fatal error LNK1120: 33 unresolved externals
Error executing link.exe.
thank you so much!.
ZlamalJakub
New Contributor III
Are there compiler errors oronly linker error?
I can only suggest:
1. Try to rebuild library (may be some compiled file is not p to date)
2. check include paths if they are the same in debug and release version.
I never obtain this kind of error when building release version.
Jakub Zlamal
