29391 Discussions
error: ifort not found in PATH when using abaqus in ubuntu
Haiyang_Z_
Hi dear all
When I trying to use a subroutine in Abaqus(6.11.3) error occurs: Problem during compilation: ifort not found in path.
I tried the intel fortran 2011 & 2013, this error is always there. and I had already modified the .bashrc by adding the "export path=******"..
Please help me
Thanks and wish you all a nice day.
Haiyang
TimP
Did you try sourceing the compilervars script, as recommended? Try first from command line shell, to be sure you have the right command, before putting in .bashrc Try doing it specifically the way Abaqus recommends, if they provide instructions. Do they support Ubuntu?
Haiyang_Z_
Hi Tim
Thanks for your reply . I have tried sourcing the compilervars and after that I modified the .bashrc..and still not working.
I am wondering if the abaqus 6.11 could work with fortran 12.1. so I am going to try the abaqus 6.13
I will let your know if it works.
Thanks again.
Haiyang
TimP
I agree that it would be desirable to have a version of Abaqus which works with ifort 12.1 or newer as such ifort versions have improved support for Ubuntu.
