29651 Discussions
exit codes to shell from main? exit()?
jkwi
What is the correct way to pass exit codes from a FORTRAN main to the calling shell?
In the past we've used:
call exit(icode) where icode is an integer byte.
call exit() seems to work fine but there is no function I could find in the documentation.
Seems to be a supported extension?
What library is this function in?
EXIT is a reserved word for exiting out of DO loops.
Thanks for any info.
Kevin_D_Intel
Look for "EXIT Subroutine" in the Intel Fortran documentation.
EXIT Subroutine
Intrinsic Subroutine (Generic): Terminates program execution, closes all files, and returns control to the operating system. Intrinsic subroutines cannot be passed as actual arguments.
Syntax
CALL EXIT [( [status] )]
status (Output; optional) Is an integer argument you can use to specify the image exit-status value.
The exit-status value may not be accessible after program termination in some application environments.
mecej4
Fortran does not have reserved keywords. Thus, the following code, while reprehensible, is legal:
[fortran]logical :: then, if, else, exit
integer :: i
do i=1,5
  if = then.or.else.and.exit
  if(if)then
    then=if
    exit
  else
    else=if
    call exit(3)
  endif
end do
..[/fortran]
