f03 array allocation
mataras__dimitrios
IVF 16 compiles the following code with 0 errors, 0 warnings,
program main
    implicit none
      integer:: i
      real, allocatable:: a(:)
      real:: c(5) = [(i, i = 1,5)]
     a = c     !   allocation F03
     print *, '  array a has ', size(a), ' elements:'
     print *, a
end program main
The output is that the array has 0 elements and of course no values. Apparently the F03 style allocation in the assignment statement a=c does not work as it should.
The program runs correctly with 2 other compilers.
Is the F03 allocation feature not implemented in IVF 16?
BR
Dimitris
mecej4
The default in Intel Fortran is not to reallocate an allocatable variable that is assigned an expression of a different size than the current allocated size, for performance reasons and to fulfill customer preference. Use the /assume:realloc_lhs option, as in ifort /assume:realloc_lhs assign.f90.
TimP
Did you read about compile options /assume:realloc_lhs and /standard-semantics?
mecej4
mataras__dimitrios
Thanks everyone, I missed the option. it works ok.
BR
Dimitris
