/fast option
MiB1980
I am trying to optimize my code and using /fast option.
I get the following error :
libifcoremt.lib(libifcoremain.obj) : error LNK2019: unresolved external symbol _MAIN__ referenced in function _main
What does this error mean ?
Sigh - should have realized that would do no good - the .obj files just contain intermediate language for IPO.
At this point I will ask you to try this with a current, supported release,preferably 11.1. If you can't do that, then I suggest disabling /Qipo for this project. It may be that it is doing something inappropriate for your main program.
TimP
Quoting - MiB1980
This appears to mean that you don't have a successfully compiled Fortran main program in your object file list.
MiB1980
The program compiles when I dont use the /fast option. Is there any particular reason for the IVF to give this error when using the /fast option?
I can't imagine what /fast would do that would prevent you from linking. Does this happen to all programs or just one (or some)?
/fast is just shorthand for a set of options that can improve performance, at the expense of compile time. It also sets /arch:host (in 11.x) which means the program typically needs to run on the same system that compiled it.
MiB1980
I am linking three other static library projects as dependencies with my main ( different name) program
The three libraries compile with /fast option but not the main program.
A similar scheme (libraries + main + /fast) succeeds on the same machine for some other solutions.
Please do this. In your main project, go to the Linker > General property page and select Show Progress Messages to "Show all progress messages (/verbose)". Do a rebuild of the main project. Go into the Release subfolder and find buildlog.htm. Zip it and attach the ZIP to a reply here (see below for atachment instructions.)
MiB1980
Attaching the zip here...
Thanks. I see you are using 9.1. You've also added /QxN /QaxN, which seems rather pointless to me - especially as /fast overrides those (though I've forgotten what 9.1 uses instead.)
There are also two unresolved references to MATVEC and MSOLVE - where are those defined? Can you attach main.obj?
What happens if you replace /fast with /Qipo? Remove the /QaxN - it isn't doing anything useful for you.
MiB1980
Thanks a lot for your help...
(I have removed the /QxN and /QaxN options)
/fast and /Qipo gives the same results.
MATVEC and MSOLVE are subroutines defined in the same main project. When I dont use the /fast option I dont see the unresolved warning in the build log. I am attaching the main.obj here.
MiB1980
It works in 11.1...
Thanks for the help..
