29649 Discussions
fatal error LNK1000: Internal error during BuildImage
cfann61
Mixed language solution, Fortran/C++. When I build the solution and direct the output( two .dll files ) to one file folder, it builds successfully. When I try to build in another folder, which is inside of the previous folder, I get the build error
Chris
My advice is to never set the output of two different projects to the same folder - this can cause all sorts of build problems. Instead, add a post-build step to copy the DLL to some other location (say, the project folder of the executable project). You may be running into an issue with Visual Studio trying to build two projects in parallel.
Does this help?
Does this help?
cfann61
Steve,
That does help, I was just trying to take a short cut. Thank you.
