29607 Discussions
fatal error LNK1104: cannot open file libmmdd.lib
Felix_Froehlich
just upgraded from version 11.0 to Visual Fortran Composer XE 2011 (12.0.3470.2008) with VS 2008 and am getting a linker error:
The file in question is only present here \\Intel\\ComposerXE-2011\\compiler\\lib\\intel64\\, but not in the \\ia32\\ directory. Using the file in \\intel64\\ does not work (as I am compiling for 32bit).
Please advise on how to fix this / get the missing file.
Ah, I have seen a couple of reports of this but have not been able to reproduce it. Uninstall and reinstall of Fortran fixed it for these people.
Perhaps you installed only the Intel 64 subset product? Please download and install the variant with a name ending in _novsshell.exe to make sure you get boith the IA32 and Intel 64 files.
Felix_Froehlich
This is the installation package I used: w_fcompxe_novsshell_2011.1.127.exe
I do have an IA32 folder and corresponding files, just the libmmdd.lib seems to be missing.
Felix_Froehlich
OK thanks, uninstalling and reinstalling worked. (repair install did not resolve the problem).
joey_hylton
Just updated to XE 2015 update1 composer, then got this error.
Previously have installed XE2015 with VS2010 shells.
JL
############ updates ##################
uninstalled XE 2015 and update 1, re-installed update 1, worked.
No, you'll need to reinstall.
