29648 Discussions
fatal error LNK1104: cannot open file 'ucrt.lib'
AlexG1
After I installed latest versions of Intel API Base and HPC toolkits, I cannot link any of my old Fortran projects. The "Nuild" command in all versions of Vsual Studio 2019, 2022, and 2026 end with this
Please help!
Shiquan_Su
Hi, Alex:
During your installation and integration, did you choose "Desktop development with C++" in the menu? That is a common situation that leads to not finding the library.
The library itself is typically in a path similar to this:
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22000.0\ucrt\x86
Can you find that on your system?
You can manually feed the path to your VS settings as a workaround.
This lib is part of Windows, and is not related to the Intel OneAPI product. This is not an Intel OneAPI product issue. It is a Microsoft Visual Studio integration with Intel OneAPI issue.
Shiquan_Su
Hi, Alex:
AlexG1
I was talking about a Fortran project, not C++ project.
I reinstalled from scratch VS 2026 and then Intel API toolkits. After that, the problem disappeared.
