fcntl byte range locks
happyIntelCamper
Trying to implement byte range locks using fcntl in fortran 90. The file system honors them.
Structure on 'handle' seems to get created ok. But 'pxffcntl' call returns 9 which indicates a problem
with the call. What am I doing wrong?
! compile/link string
! ifort -I/pgsdev/com/intel/intel11.1.072/impi/4.0.0.028/include64
! -L/pgsdev/com/intel/intel11.1.072/impi/4.0.0.028/lib64 -lmpi -g
! PioProb.F90 -o pioprob -lmpiif -Bstatic
program PioProb
use ifposix
#include
integer ier, nprocs,rank,ix,iy,iz,bg,ed,mid,i
integer arg,arg2
logical conflict
integer(kind=8) ind,imgsze,start,length
real, allocatable,dimension(:,:) :: buf,master
integer:: locks(1)
integer,parameter :: nz=212
integer,parameter :: nx=4617
integer,parameter :: ny=602
integer,parameter :: cubesz=513
character(1000) :: ascii,dat
integer win,whichone,un,handle,iargout,ilen
allocate(buf(nz,nx))
allocate(master(nz,nx))
ascii = "/datadb/jimmccp/mde/testfile"
dat = "/cfs11/jimmcc/testfile_@"
call MPI_INIT(ier)
call MPI_Comm_size(MPI_COMM_WORLD,nprocs,ier)
! if(nprocs/=9)then
! stop "run this with 9 processes"
! endif
call MPI_Comm_rank(MPI_COMM_WORLD,rank,ier)
if(rank==0)then
open(10,file=ascii,status="unknown",form="formatted",iostat=ier)
if(ier/=0)then
stop "can not open ascii file"
endif
write(10,*)"axis=z xline subline"
write(10,*)"size.z= ",nz
write(10,*)"size.xline= ",nx
write(10,*)"size.subline= ",ny
write(10,*)"delta.z= 20"
write(10,*)"delta.xline= 1"
write(10,*)"delta.subline= 1"
write(10,*)"origin.z= 0"
write(10,*)"origin.xline= 1"
write(10,*)"origin.subline= 1"
write(10,*)"inc.z= 20 "
write(10,*)"inc.xline= 1"
write(10,*)"inc.subline= 1"
write(10,*)"base.z= 0"
write(10,*)"base.xline= 1"
write(10,*)"base.subline= 1"
write(10,*)"format=fcubex"
write(10,*)"data= "//trim(dat)
close(10)
open(20,file=dat,action="readwrite",status="unknown",access="stream", &
form="unformatted",iostat=ier)
un = 20
if(ier/=0)then
stop "can not open data file rank 0"
endif
buf = 0
do iy = 1, ny
write(un,iostat=ier)buf
enddo
endif
if(rank>0)then
open(20,file=dat,action="readwrite",status="old",access="stream", &
un = 20
if(ier/=0)then
stop "can not open data file non zero rank "
endif
endif
imgsze = nx*nz*4
call MPI_Barrier(MPI_COMM_WORLD,ier)
CALL PXFSTRUCTCREATE ("flock",handle,ier)
call pxfintset(handle,"l_whence",ipxfconst("SEEK_SET"),ier)
do whichone = rank, 9, nprocs
do iy = 1, ny
length = 4*nx*nz
start = (iy-1)*length
write(*,*)'rank ',rank,' read/write offset=',iy
! lock
call pxfintset(handle,"l_type",ipxfconst("F_RDLCK"),ier)
call pxfint8set(handle,"l_start",start,ier)
call pxfint8set(handle,"l_len",length,ier)
CALL PXFFCNTL (un,ipxfconst("F_SETLKW"),handle,iargout,ier)
ind=imgsze*(iy-1)+1
read(un,pos=ind,iostat=ier)master
if(ier/=0)then
stop "can not read data file "
endif
bg = 1+whichone*cubesz
ed = 1+(whichone+1)*cubesz
mid = bg+256
buf = 0.0
do ix = bg+1, ed-1
val = sqrt(150.0**2-(float(ix-mid)**2+float(iy-301)**2))
iz = val
if(iz>=0 .and. iz<=nz)then
buf(iz,ix)=1.0
endif
enddo
master = master+buf
write(un,pos=ind,iostat=ier)master
if(ier/=0)then
stop "can not write data file "
endif
flush(un)
! unlock
call pxfintset(handle,"l_type",ipxfconst("F_UNLCK"),ier)
enddo
enddo
close(un)
write(*,*)'rank ',rank,' at end'
deallocate(buf,master)
end program PioProb
