final routines in fortran 2003
Hafsia__Aouididi
I am testing the finalization of a derived type parameterized and i got errors when calling final .
This is the code :
module tests
implicit none
  private
  public :: mytab
  type  mytab(n)
    integer, len :: n
    integer :: tab1(n)
contains
    final :: delete_mytab
#ifdef __GNUC__
      procedure :: delete => delete_mytab_gfortran
#endif
    end type mytab
   interface mytab
      procedure create_mytab
    end interface mytab
  contains
    !Constructor
    function create_mytab(n)
      type(mytab(:)),allocatable :: create_mytab
      integer, intent(in) :: n
      allocate(mytab(n) :: create_mytab)
    end function
    !Destructor
    !nothing to do in this example
    subroutine delete_mytab(this)
      type(mytab(:)),allocatable :: this
    end subroutine
#ifdef __GNUC__
    subroutine delete_mytab_gfortran(this)
      class(mytab(*)) :: this
    end subroutine
#endif
end module tests
and this is what i get when compiling whith ifort 18.0
rror #8339: The dummy argument of a final subroutine must be a variable of the derived type being defined and cannot be optional, pointer, allocatable, or polymorphic.   [THIS]
 error #8738: All length type parameters of the dummy argument must be assumed for a final subroutine.   [THIS]
And when i call the derived type without the allocatable this is what i get :
#8730: A colon may only be used as a type parameter value in the declaration of an object that has the POINTER or ALLOCATABLE attribute.   [THIS]
      type(mytab(:)) :: this
Juergen_R_R
Valued Contributor II
The Fortran Standard says in 7.5.6.1, C787:
A final-subroutine-name shall be the name of a module procedure with exactly one dummy argument. That argument shall be nonoptional and shall be a noncoarray, nonpointer, nonallocatable, nonpolymorphic variable of the derived type being defined. All length type parameters of the dummy argument shall be assumed. The dummy argument shall not have the INTENT (OUT) or VALUE attribute.
Look in Sec. 7.2 of the standard where type parameters are introduced. 7.2.4, C702 says:
A colon shall not be used as a type-param-value except in the declaration of an entity that has the POINTER or ALLOCATABLE attribute.
In 7.2.7, we have
An asterisk as a type-param-value specifies that a length type parameter is an assumed type parameter.
So this works:
    type(mytab(*)) :: this
  end subroutine delete_mytab
Juergen_R_R
In 7.2.7, we have
So this works:
Hafsia__Aouididi
Thanks . Well it actually works now .
i still have another problem it doesn’t work neither with gfortran nor with flang.
I  ll try to fix this :)
Juergen_R_R
Yes, the parameterized derived type implementation is still quite buggy, and flang is not even nearly a full F2003 compiler.
Steve_Lionel
Neither is gfortran (well, it's a lot closer at least.)
