floating point exceptions
jaroberts2
Hi, I just installed the latest Intel Fortran compiler (noncommercial) on a Ubuntu 9.04 system (running w/ AMD64). I'm pretty new to ifort, and I'm not sure why I'm unable to stop floating point exceptions.
Example program:
program test
implicit none
real :: a, b
a = 0.0
b = 0.0
print *, a/b
end progam test
If I compile this using
>>$ ifort -fpe0 test.f90 -o testx
I would expect execution to halt and declare an exception, but it doesn't and simply prints NaN.
Any suggestions?
TimP
Quoting - jaroberts2
program test
implicit none
real :: a, b
a = 0.0
b = 0.0
print *, a/b
end progam test
In this case, you would expect the compiler to evaluate a/b as NaN (non-signaling?), regardless of any run time behavior you attempt to set.
In certain past Unix-like operating systems, you might capture run-time exceptions without invoking IEEE_EXCEPTIONS, by running under debugger with specific options set, but I fear there is no exact equivalent available in linux. Anyway, you would be searching for exceptions raised at run time, not at compile time.
jaroberts2
Quoting - tim18
Ah, I should have been a bit clearer. I expected the exception (NaN) at run time. I get the expected behavior when I compile the same using gfortran with the -ffpe-trap=invalid flag. I did test the same code on another linux machine (I'm not sure of the exact breed nor the exact ifort version) and it also gave the exception.
TimP
Did you perhaps not set -O when you used gfortran? Remember that ifort defaults to -O2, and there is aggressive compile-time constant propagation, while gfortran defaults to -O0.
jaroberts2
Quoting - tim18
I had included -O0 earlier, and it didn't help. I just verified that it does not change my situation.
Is there anything else I might be missing?
