floating point problem?.
taka2488
I use Intel fortran compiler.
My problem is the executed result of ivf (Intel Visual Fortran) project is different from that of cvf (Compaq Visual Fortran) project.
Both has the same code.
For example,
## sample code #######################################
PROGRAM float
P=0.9935059
P0=1.03323
C
P=AMIN1(500.0,P+P0)-P0
C
WRITE(6,*) P
END
This result is
0.9935058 in ivf
0.9935059 in cvf
I think cvf result is currect.
Please teach me this problem.
cf, This ivf project was converted from cvf.
and
This is my lacktop specification.
OS : Windows Server 2003
CPU : Intel Xeon CPU E5335 @ 2.00GHz
TimP
If you haven't read about the compile options for both ifort and CVF please do so. With current 32-bit ifort, if you wish to evaluate simple expressions in double precision, as CVF did, /arch:ia32 should work. It would be preferable to write what you mean in standard Fortran, e.g.
P=MIN(500.0d0,dble(P)+P0)-P0
(if you don't like Fortran 90), so that your result doesn't depend on the compile options.
You have used one bit of f77, so I won't try to show you an f66 version.
As mentioned further down, these compilers are evaluating your expressions at compile time, sorun time settings will have no effect, and the current compiler is technically correct in doing what you asked rather thanwhat you may have meant.
I tried /arch:ia32 on this program, as well as /fp:source, but it didn't change the result. I will comment that this computation is right on the edge of what is representable in single precision and it does not surprise me that a one-LSB difference might be seen between implementations.
I'll have to see what CVF is doing differently.
jimdempseyatthecove
Also, the diffrerence may be only in the print routine but not in the binary representation.
Try printing using anZ (hex)format
Jim
Jeffrey_A_Intel
Without looking at any code generated by either IVF or CVF, I think CVF is carrying out the computation in extended precision in the x87 register set and IVF is doing the computation in single-precision (as the code specifies) in the SSE registers.
If one does allthe arithmetic in IEEE single-precision, the result of (P+P0)-P0 is smaller than P by 1 lsb. The reason is alignment/normalization shifts:P0 is shifted right one place in the addition and there is another right shift to normalize the sum. Then there is a left shift of two places to normalize the result of the subtraction.
Obligatory reference to Goldberg's paper on floating-point arithmetic: http://dlc.sun.com/pdf/800-7895/800-7895.pdf
When compiled with optimizations, both compilers do all the arithmetic at compile-time. Here's what the instructions look like without optimization - I've done some annotation.
CVF:
fld dword ptr .bss8 [push P on FP stack]
fadd dword ptr .bss4 [add P0 to P]
fcom dword ptr .literal8 [compare sum against 500.0]
mov eax, 0 [this and next four instructions are the rest of the AMIN]
fnstsw ax
and ah, 65
jne L$1
fstp st(0)
fld dword ptr .literal8 [store 500]
L$1:
fsub dword ptr .bss4 [subtract P0 from sum]
fstp dword ptr .bss8 [store P]
IVF:
fld DWORD PTR [_2il0floatpacket.2] [push 500.0 on FP stack]
fld DWORD PTR [-12+ebp] [push P on FP stack]
fld DWORD PTR [-8+ebp] [push P0 on FP stack]
faddp st(1), st [add P and P0]
fcom [compare sum to 500]
fnstsw ax [this and next 4 are the AMIN]
sahf ;5.1
ja L1 ; Prob 50% ;5.1
fst st(1) [copy sum to FP stack location 1]
L1: ; fstp st(0) ;5.1
fsubp st(1), st [subtract P0 from sum]
fstp DWORD PTR [-12+ebp] [store P0]
I am not an expert on the instruction set and I have to admit I don't understand everything here, but it looks to me as if the arithmetic instructions are equivalent. The only thing I can't see is what precision mode each compiler sets the X87 registers to. When I debug, the CVF display shows me one additional digit in the FP registers - I don't know if this is relevant.
Nevertheless, Jeff correctly notes that if you do the computation in declared precision, IVF gets the correct answer.
Melvin_Robinson
Using Intel Visual Fortran 10.0.025 I get the correct answer of 0.9935059 which is the correct answer.
Quoting - Melvin
"correct" is a matter of interpretation here. I'll agree that, arithmetically, with infinite precision, that is correct. Computationally, with single-precision floating point, it is incorrect.
Melvin_Robinson
Sorry if I'm the only one on this thread who doesn't understand this, (that's what I get for jumping in and compiling code) but why is the answer incorrect when using single-precision arithmetic?
Quoting - Melvin
See Jeff Arnold's reply above. It is a difficult topic that most do not understand, leading to occasional surprising results.
jimdempseyatthecove
Assume the "correct" answer were
1.234567891011121314151617181920
But single precision real(4) has limited precision capability which is +/- not quite 7 digits
The above resultant value cannot be completely held, only the rounded value can be held
1.23456? where ? is neither 7 nor 8 but some value between 7 and 8.
Open the Windows calculator, enter 1/3, do you see or expect an infinite number of 3's?
2/3 do you expect to see an infinate number of 6's or all 6's or all but last as 6's and one last 7?
In each of the above cases, are you willing to accept theresult as close enough?
Here is another reference on floating pointstorage
http://steve.hollasch.net/cgindex/coding/ieeefloat.html
Jim Dempsey
