flush error
taoz
Hi, all,
I have got a problem when using the internal function flush.
call flush(88)
The error message for the above command is
undefined reference to `flush_'
The manual says this is a internal lib function. Even when I specified the path of the lib, '-L/opt/intel/compiler70/ia32/lib', in the compiling line, it doesn't work. Could anyone help me out?
thanks,
Tao
Which compiler version are you using? Do you have an EXTERNAL FLUSH declaration? Take it out if you do.
taoz
No, there isn't any other external function/subroutine. I did a another test, here is the code and result.
code:
program main
write(88,*) 'test'
call flush(88)
end
compiled with
ifc t.f -L/opt/intel/compiler70/ia32/lib
program MAIN
4 Lines Compiled
/tmp/ifcK4GJKO.o: In function `main':
/tmp/ifcK4GJKO.o(.text+0x49): undefined reference to `flush_'
Here is the version info
ifc -V
Intel Fortran Compiler for 32-bit applications, Version 7.1 Build 20031225Z
Copyright (C) 1985-2003 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
GNU ld version 2.11.93.0.2 20020207
Supported emulations:
elf_i386
i386linux
elf_i386_glibc21
/usr/lib/crt1.o: In function `_start':
/usr/lib/crt1.o(.text+0x18): undefined reference to `main'
Is there any wrong with the ifc installation?
thanks,
Tao
Oh, 7.1. Hmm. Try adding -vaxlib
taoz
It works. thanks a lot.
Tao
