format syntax error
Luis2
Hi
By default the debugger does not detect the format error
print a ! instead print *,a
I have inspected the project properties and can not find how to change this
Peter
Quoting - Luis
Hi
Luis,
What compiler are you using???
lklawrie
I think it will be hard for the compiler (any compiler) to detect your intentions here as the print statement has changed with standards:
print a
suggests using a as the format -- no longer do formats have to be numbers and format statements. With some compiler settings, you would probably get an error at runtime.
Linda
Luis2
I'm using ivf 10.1
The error is trivial. Simply, I was surprised that is not detected at compile time.
Perhaps an formated output can not be detected,but I thought that
print a
is an easily detectable error
lklawrie
variable a could just as easily be defined as "('type this here')"
and thus print a would produce:
type this here
on the output line.
in old style fortran, any kind of variable could hold a string. that's why i say it might be detected during runtime but not perhaps during compile time.
Linda
TimP
Certain compilers, such as gfortran, will check the contents of a constant format string at compile time. Some of those checks happen with ifort only at run time, perhaps only when -check format has been set at compile time, and only when use of the format is attempted. The run-time check has the advantage of applying to variable as well as constant formats, but the disadvantage of not catching problems not exposed by a test run. The function of the debugger would be to help determine what led up to the problem, perhaps not needed in the present case.
Luis2
I would not expect the debugger to do anything with this. The program should generate a run-time error.
Yes, in my first post I should have written compiler, not debugger
In my little program a is a character
program main
character(len=5) a; a='foo' ; print a
end program
but the compiler does not catch any error, as expected the program crash when I run it.
It really is a bug when I was writing a code, I Do not expect the statement works in a different way.
Peter
Quoting - Luis
program main
end program
Oh!!... That makes a lot of difference when you say 'debugger' instead of 'complier'.
Possibly it might be expecting a namelist, while it is compiling; when you debug it gets upset since it wasnt namelist ! Thesyntax for Print for namelist is
print nml
where
nml=Is the nonkeyword form of a namelist specifier (no NML=) indicating namelist formatting.
This might be a possibility only!
I already explained that this program is perfectly valid Fortran syntax, which is why the compiler did not complain. It thought you had a run-time format string in variable A. Since you didn't, you got an error at run-time.
Luis2
I understand
program main
character(len=5) a
a='("foo")'
print a ! foo
end program
Thank you
