forrtl: The parameter is incorrect
fbalderasintel
Our Fortran application dies suddenly with a terse statement "forrtl: The parameter is incorrect".
Is there a way to get the run time lib to dump out more information ?
v2013 composer update 5.
This is a Windows API error that can have many possible causes. Do you know what operation was executing when you got this error? Is there a traceback? It could be that there is data corruption, and malware can also cause this in some cases.
fbalderasintel
Forgot to mention. The program is run from command line. When it dies, the window closes. Is there a way to keep the command window open after a program dies?
If the program is run from the command line, as opposed to a console application that opens the window when it is run, then the window closing indicates that the Windows command prompt process died, which is not good. It's also not a Fortran issue - you might have more serious problems with this system.
If it is just a console app you ran by double-click or some other way, then Windows will close the command window when the image exits.
