29650 Discussions
forrtl: severe (157): Program Exception - access violation
Alex_P_4
Dear Forum,
I keep getting 'forrtl: severe (157): Program Exception - access violation' error on execution and I have no clue how to fix it. I know this topic has been discussed before but in different contexts. I need a fresh eye to see the problem in my program.
I am am minimizing a finction by calling a minimization routine in the main program:
use definitions
integer, parameter :: N1=2
    integer :: IPARAM(7)
    double precision :: X(N1), X0(N1), XLB(N1), XUB(N1), RPARAM(7)
    double precision :: F
XLB = (/-2.d0,-1.d0/)
XUB = (/.5d0,2.d0/)
X0 = (/.1d0,.25d0/)
!X = (/1.0d0,2.d0/)
IPARAM(1) = 0
F=2.d0
!CALL D_BCONF (FCN, IBTYPE, XLB(N), XUB(N), X(N) ,| N, XGUESS(N), XSCALE(N), FSCALE, IPARAM, RPARAM, FVALUE)
CALL D_BCONF (FCN1, 0, XLB, XUB, X, 2, X0, , , IPARAM, RPARAM, F)
write(*,*) X, F
Function FCN1 is called from a different file containing module 'definitions':
MODULE definitions
INCLUDE 'link_fnl_static.h'
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
!use imsl_libraries
implicit none
save
............ (other routines in the module)
SUBROUTINE FCN1 (N1, X, F)
implicit none
integer :: N1
double precision:: X(*), F
F = 1.0d2*(X(2)-X(1)*X(1))**2 + (1.0d0-X(1))**2
END subroutine FCN1
end module
I have done it before many times in Compaq Visual Fortran and it always worked. Now it refuses to do it.
I noticed that if I remove comment mark from statement !X = (/1.0d0,2.d0/), it executes but it appears that fortran does not see the minimization call CALL D_BCONF(). There is no output, X is still the same and the function value is F = 0.25 (I do not know where it comes from).
Any ideas as to how I can make it work? I will provide any other info necessary to resolve the issue.
Thanks for any help.
If you are going to call the "Fortran 90" interface versions of the IMSL routines, you MUST have USE BCONF_INT, etc. (or USE IMSL_LIBRARIES). You commented that out. Otherwise there will be an argument passing mismatch. Also, please do not use the D_ and S_ versions of the names - call the generic name instead (BCONF).
andrew_4619
I think the error is the optional aguamnents with ,,,
try something like :
CALL D_BCONF (FCN1, 0, XLB, XUB, X, 2, X0,IPARAM=IPARAM, RPARAM=RPARAM, FVALUE=F)
