Hi guys!
I need your help again, I'm having the following error:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
this error is in the following line:
dx_step_man_neg = (ABS(acc_limit_neg) - ABS(usage_transformed%exceedance_man_values%acceleration_neg(1)))&
/n_step_man
if I remove the ABS operator the error disappears, but I need the ABS operator, do you have any suggestion or idea why is this happening?
Thanks again!
Juan
Does raising the stacksize limit help?
Quoting - pze593@my.utsa.edu
Can you be more specific?
http://software.intel.com/en-us/forums/showthread.php?t=61486
Thanks, but it is unclear for me where do I need to type thesecommands:
For Bash/sh/ksh use:ulimit -s unlimited
For Csh use:limit stacksize unlimited
Juan
You type them at your Linux (or Mac OS) shell prompt. The command varies depending on which command shell you are using. Try one and if that is unrecognized, try the other.
Quoting - Steve Lionel (Intel)
Thanks Steve for all your help,
Is this message normal?
macbook:Fixing_after_st_louis_mde juanocampo$ ulimit -s unlimited
-bash: ulimit: stack size: cannot modify limit: Operation not permitted
Juan
Quoting - tim18
I don't know MacOS, but I've seen platforms where you must set unlimited as root before you will be permitted to set it as a user.
Macs come with a default 8K stack, pretty puny.
AND they limit the stacksize to 64K MAX. It's built into the kernel.
Try
ulimit -s 60000
that will kick it up to about the maximum.
AND compile with this option:
-heap-arrays
ron
Quoting - Ronald Green (Intel)
Try
ulimit -s 60000
-heap-arrays
ron
It was a good try, but it didn't work.
Thanks Ron, any other help guys?
first check your stack:
ulimit -s
if you think it is small, increase it (it is safer to increase it to unlimited).
but i have 2 question! what causes the necessary stack to shoot up when we use opnmp? is it private variables?
is there any way in fortran to check the stack size required and adjust it in runtime?
ulimit -s
When you enable OpenMP, you change the default allocation of arrays (and other non-scalars) from static to automatic. This means they go on the stack by default, and if you have large arrays that will increase stack size.
You can try -heap-arrays to see if that helps.
This is sofrustrating, that didn't work.. any other suggestion, that only occurs when I'm using optimization O1, O2....
Next things to try
-fp-stack-check -check all -g -traceback -O2
then
-gen-interfaces -warn interfaces
If that doesn't show anything it's probably time to get a reproducer. Is it possible to tar up the application, input files, makefiles, etc. needed to build and run this?
Then post that tarball either here or at http://premier.intel.com.
ron
then
ron
Next things to try
then
ron
then
ron
/where i can find one?
I think that I need to get that step!
I do not understand what you are asking. First, try the compiler options I suggested. Do these show errors? If so, investigate on your own.
If these compiler options do not show errors, then create a tar file. Do you know how to do that?
Once that tar file is created, open an issue with your account at http://premier.intel.com. Include information on how to compile and run your program.
I tried to debug with thoseoptions, and it compiles, but when I'm gonna run it shows the following error:
UTSAMAC147461:Code_01_22_09 Macuser$ ./Juanito.exe
Image PC Routine Line Source
Juanito.exe 00061097 Unknown Unknown Unknown
Juanito.exe 00060539 Unknown Unknown Unknown
Juanito.exe 00035B28 Unknown Unknown Unknown
Juanito.exe 000172B4 Unknown Unknown Unknown
Juanito.exe 0001DC2E Unknown Unknown Unknown
libSystem.B.dylib 95F4909B Unknown Unknown Unknown
Unknown FFFFFFFF Unknown Unknown Unknown
Stack trace terminated abnormally.
So do I need to submited to intel?
Juan
Juan
This is the code and includes the make file...
Juan
And you did try to compile your program with compiler option -heap-arrays? And you did increase the stacksize?
What is the output of:
size Juanito.exe
Although you may have a 64bit system, a program is limited to the size of physical ram + swap space. Are your arrays too big? Can you make them small for a test run?
Did you see the post at the top of the Forum main page with instructions to attach a file to this article?
size Juanito.exe
I already try -heap-arrays and didnlt work.
My biggest array is a array with dimension 100000 (hundred thousand), the second one largest is an array (7,38).
do you think that those are the problem
sigsegv can be caused by many many things. I cannot guess what the problem is. Please open a problem report with your program, input, and instructions at premier.intel.com. Or attach your program and the instructions here.
ron
ron
Topic Options
