fortcom: Error:
desensitized
Hello, i am getting the following error when trying to complie my program. I have compiled it using the Lahey compiler with the default options and it works correctly. Here's the error message i get:
fortcom: Error: Ogive8.f90, line 183: The highest data type rank permitted is INTEGER(KIND=8).
ALLOCATE (id_point(0:nMax+1000,NGrains), STAT=STAT)
the variable decloration is as follows:
INTEGER, ALLOCATABLE, DIMENSION(:,:) :: id_point
I've also tried compiling with the following options but with no success:
ifort Ogive8.f90 -o Ogive8 -integer_size 64
If anyone has any insight that would be appreciated.
James
Ron_Green
Hmm, I need a little more context. How is NGrains declared, and what is it's value. Or better yet, on the "Options" tab you will see that you can upload a file. Is Ogive8.f90 stand-alone, or is it INCLUDing or USing half the known universe? If it's simple, upload it so we can have a look.
OR you can open an issue on premier.intel.com and upload the file there.
There's just not enough here to go on.
desensitized
Thanks but I realized my mistake. The variables i used in defining the allocation was of the wrong data type (type=real).
Stupid mistake, The Lahey compiler is more forgiving and i never caught my mistake till now.
James
