29391 Discussions
fortran calling C, more unresolved external
Brian_Murphy
New Contributor II
I thought I had this figured out, but I'm once again having trouble calling a c++ dll from a fortran dll.  I had it working, I think, but not now.  I am blind to whatever I'm doing wrong.
In c++ I have the following function definition.  I have confirmed I can call the function from Excel VBA with the argument passed to it by value.
int WINAPI CheckFileProperties(int featureID)
 In fortran I have the following interface for the above C routine.  This must be where my problems is???
	interface
		function CheckFileProperties(featureID) bind(C, name="CheckFileProperties")
			!DEC$ ATTRIBUTES STDCALL :: CheckFileProperties
			!DEC$ ATTRIBUTES VALUE :: featureID
			import
			integer(c_int) :: CheckFileProperties
        	integer(c_int) :: featureID
		end function
	end interface
Building the fortran DLL generates the following error.
error LNK2019: unresolved external symbol _CheckFileProperties@4 referenced in function _CheckKey		CheckKey.obj
The following is a dumpbin on the LIB file of the c++ DLL.  The LIB has been added to the file list of the fortran DLL.
Dump of file xlroto32.lib
File Type: LIBRARY
     Exports
       ordinal    name
                  ?CallDefl32@@YGFPAPAUtagSAFEARRAY@@0000000N00NNNFFFFFNF@Z (short __stdcall CallDefl32(struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,double,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,double,double,double,short,short,short,short,short,double,short))
                  ?CallEval32@@YGFPAPAUtagSAFEARRAY@@000000000NNNNFFFFFPAPBD@Z (short __stdcall CallEval32(struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,double,double,double,double,short,short,short,short,short,char const * *))
                  ?CallGetVersion32@@YGNN@Z (double __stdcall CallGetVersion32(double))
                  ?CallResp32@@YGFPAPAUtagSAFEARRAY@@0000000000000NNNFFFFFNFPAPA_W@Z (short __stdcall CallResp32(struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,double,double,double,short,short,short,short,short,double,short,wchar_t * *))
                  ?CheckFileProperties@@YGHH@Z (int __stdcall CheckFileProperties(int))
                  ?compute_mode_shape32@@YGFPAPAUtagSAFEARRAY@@00000000NNNNFFFFFNNN@Z (short __stdcall compute_mode_shape32(struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,struct tagSAFEARRAY * *,double,double,double,double,short,short,short,short,short,double,double,double))
                  _SetExcel12EntryPt@4
  Summary
          C6 .debug$S
          14 .idata$2
          14 .idata$3
           4 .idata$4
           4 .idata$5
           E .idata$6
Steve_Lionel
You need
extern "C"
before the "int".
Brian_Murphy
New Contributor II
Thanks, Steve.  I had that in there, but had taken it out for reasons I don't recall.  Putting it back has fixed this problem, but that naturally makes another popup.  I will start another thread for it if I don't stumble onto a fix.
Murphy's Law is in full effect - the closer you get to finishing something, the more trouble you'll have.
andrew_4619
	interface
			import
        	integer(c_int), value :: featureID
		end function
	end interface
Brian_Murphy
New Contributor II
Andrew,
What you have suggested triggers the same linker error.  If you know it should work, could I be doing something wrong elsewhere?  Could it be a bug in visual studio 2019?
The fact that I can call the C routine from VBA when compiled with or without extern "C" makes me wonder.
I'm also baffled by the absence of the LIB file from the linker command line.  The C DLL's LIB is in the source file project list, and not checked in Project Dependencies.  Yet with extern "C" in the C file, the linker error goes away.
I also just found out that with extern "C" in the C code, I can call the routine from VBA sometimes, and sometimes not as Excel crashes.  It is very inconsistent.
andrew_4619
What I wrote has no bearing at all on the linker error. You should not really use the ATTRIBUTE VALUE with bind C.
