fortran calling a cpp dll
David_Mccabe
Hi, I am writing a Fortran 2003 program which will make calls to a C++ dynamic link library. An initial call to the .dll seems to work fine however, consecutive calls return unexpected results.
My dll is composed of the files util_lib.cpp a header file util_lib.h
Heres the util_lib.cpp, the routine readLongInt should simply print a long int:
[cpp]#include
#include "util_library.h"
extern "C"
  UTIL_API void CALLING readLongInt(long a)
	std::cout<<"Here is a long int: "<<<"\n"<<:ENDL>
Here is the associated header file util_lib.h:
[cpp]#pragma once
#ifdef UTIL_EXPORTS
#define UTIL_API __declspec(dllexport)
#else
#define UTIL_API __declspec(dllimport)
#endif
#define CALLING __stdcall
extern "C"
  UTIL_API void CALLING readLongInt(long);
[/cpp]
Here is the Fortran program which calls readLongInt 3 times in succession:
Here is the smoking gun:
!DEC$ATTRIBUTESALIAS:'_readLongInt@4'::read_long
Any time you explicitly put @n in an alias, in an attempt to solve linking issues, you're just creating trouble. The reason is that the @n suffix denotes a STDCALL convention routine, and if you don't tell Fortran you're calling a STDCALL routine, you get stack corruption as the stack gets popped twice on every call.
In the C++ code, you have the define for CALLING specifying STDCALL.
The solution is to replace that directive with this:
!DEC$ATTRIBUTES STDCALL, DECORATE, ALIAS:'readLongInt'::read_long
You can remove the ATTRIBUTES VALUE directive, since STDCALL implies that, or leave it in.
An alternative is to remove the __stdcall from the #define and use this interface instead:
[fortran] subroutine read_long(a) bind(C,NAME="readLongInt")
  use iso_c_binding
  integer(c_int),value :: a
 end subroutine read_long  [/fortran]
  use iso_c_binding
IanH
While you are fixing up that interface change C_INT to C_LONG to avoid future confusion/problems.
David_Mccabe
Problem solved, thanks!
so the lesson is, decoration in the alias is incompatablewith C or STDCALL attribute.
@IanH
thanks for spotting that, I will change it right away. One of my other cpp dlls uses an unsigned int argument, I was going to pass itinteger*4, but perhaps I should rethink?
The @n decoration is specific to STDCALL. If you had specified STDCALL in the Fortran, it would have worked. I suggested using the DECORATE attribute to let the compiler worry about the decoration, but I think the better solution is to remove the STDCALL on the C++ side.
