fpconstant issue
Adrian_F_1
I always use /fpconstant to save having to append d0 to all my constants.  As far I was aware this has always worked.  But now it works for one constant but not another.
      program ww
      implicit none
      real*8 :: KTOFShift      = -459.67
      real*8 :: KTOFFact       = 1.8
      write(6,*) KTOFShift
      write(6,*) KTOFFact
      end
gives:
ifort  ww.f90
ww
  -459.670013427734
   1.79999995231628
ifort  ww.f90 /fpconstant
ww
  -459.670013427734
   1.80000000000000
ie. the second constant gets doubled, but not the first.  Why?
mecej4
I found that if you write +459.67 on Line-3, instead of -459.67, the correct 64-bit representation is produced. I have not experimented to check whether this incorrect behavior occurs with all negative constants.
[P.S.]Correction: I had actually tried '459.67' instead of '+459.67'. See #8.
I find that this has been broken for many years - going back to 12.0 (earliest I tried it with). Very strange. It also works ok in assignment statements and DATA, but not initialization expressions in a declaration. I will report it to the developers, but also strongly suggest that you modify your code to not depend on this nonstandard behavior. Issue ID is DPD200371869.
Adrian_F_1
What is the standard?  To write d0 after every constant?  Very ugly.
The standard is that if you leave off D0 or a kind specifier then it is a "default real" value or single precision. You can use D0 or you can use a kind specifier. "real*8" is also nonstandard.
A standard approach would be:
integer, parameter :: DP = SELECTED_REAL_KIND(15,100)
real(DP) :: KTOFShift = -459.67_DP
Adrian_F_1
_DP just as ugly as D0.  So /fpconstant is being phased out?
Adrian
Adrian_F_1
I got the same problem:
  -459.670013427734
   459.670013427734
   1.80000000000000
mecej4
What I tried was the program
program ww
implicit none
real*8 :: KTOFShift      = 459.67
write(6,*) KTOFFact
end
which gave the following output when compiled using the 15.0.4.221 compiler with /fpconstant:
   459.670000000000
   1.80000000000000
From your response, I gather that the circumstances when the error occurs are more shrouded.
Adrian_F_1
program ww
implicit none
write(6,*) KTOFFact
end
   459.670000000000
   1.80000000000000
I changed the - to a +:
      real*8 :: KTOFShift      = +459.67
and still got:
   459.670013427734
   1.80000000000000
However if I remove the '+' sign it works as you say.  Very odd indeed.
mecej4
A different output depending on whether or not a '+' sign is prefixed? Totally unexpected! Perhaps, the promotion of the constant is skipped if either the '+' or the '-' prefix is seen?
Adrian_F_1
So it seems:
      program ww
      implicit none
      real*8 :: KTOFShift1     = 459.67
      write(6,*) KTOFFact
      write(6,*) KTOFShift1
      end
gives:
   1.80000000000000
   459.670013427734
   459.670000000000
I think you're right.  Adding the '+' or '-' prefix probably makes it a calculation apart from a raw constant.  However I have always expected /fpconstant to work when the constants are embedded in a formula, which would obviously include calculations.
Maybe Steve has an answer here as I'm loathed to start adding D0 or _DP to all constants in 400,000 lines of code.
NotThatItMatters
I must admit, I started adding _DP or the like 9 years ago with my 300K lines, and I have never felt confident enough to let the /fpconstant go.
Oh, well.
We have no plans to "phase out" /fpconstant, but your using it makes your code nonportable so I recommend against it. Yes, the use of the + or - sign in this specific context is what triggers the bug.
mecej4
Adrian F., please see if you can build and use the conversion utility "stod" at ftp://ftp.math.utah.edu/pub/misc/index.html#dtosstod to convert your source code so that the real constants are replaced by double precision versions in standard notation. You need the GNU Flex library, which can be installed inside Cygwin, or in Linux/Unix.
Adrian_F_1
Thanks but...
page not found.
mecej4
Adrian F. wrote:
Thanks but...
page not found.
I do not know why your browser had a problem with that URL. I clicked on the link in your reply in Chrome (Windows) and was taken to the page immediately. Try again, using the part of the URL preceding '#', or start with http://www.math.utah.edu/~beebe/software/fortran-tools.html and work your way to the download link, starting at the "dtosstod" entry under "Table of Contents".
Caution: the program "stod" goes beyond converting literal constants. It also converts declarations, references to intrinsic functions, etc.
Adrian_F_1
I use Chrome.  Tried in Firefox and IE, both couldn't find it.  Tried without the bit after the #, but all still failed.  Maybe it's a country block?  I'm in UK.
Pity that Fortran doesn't treat real constants as double like C though.
mecej4
Here is the URL for the author's home page: http://www.math.utah.edu/~beebe/ . If you cannot access that, I don't know what to suggest. The software appears to have no distribution restrictions.
Adrian_F_1
Thanks I can access that.  However I got as far as: http://www.math.utah.edu/~beebe/software/fortran-tools.html
However when I click on the ftp link it fails.  It might be some ftp restrictions on my side, I will check tomorrow.
Adrian_F_1
Tried 3 different browsers on 2 machines, but all failed to find this webpage.  Perhaps you could download it for me and post it somewhere?
Adrian_F_1
Incidentally it seems ok when in code:
      program ww
      implicit none
      real*8 :: KTOFShift1     = 459.67d0
      real*8 :: test
      write(6,*) KTOFFact
      test = KTOFShift1 - 459.67
      write(6,*) test
      end
   1.80000000000000
  -459.670013427734
   459.670000000000
  0.000000000000000E+000
