full screen
jmloriot
Full screen:
How can the program run automatically in full screen ?
I wrote the following :
status=getwindowconfig(wc)
ecranx=wc.numxpixels
ecrany=wc.numypixels
wc.numtextcols=-1
wc.numtextrows=-1
wc.numcolors=-1
wc.title='my program'
wc.fontsize=-1
status=setwindowconfig(wc)
call setviewport(0,0,int2(ecranx),int2(ecrany))
winfo.type=qwin$max
i = SETWSIZEQQ(0, winfo)
n=initializefonts()
i=setfont('n1')
i=setbkcolorrgb(rgbtointeger(0,0,100)) ! blue
i=setcolorrgb(rgbtointeger(200,200,0)) ! yellow
call clearscreen($gclearscreen)
Then I have to click to VIEW-FULL SCREEN (or to hit Alt-Enter) to go to full screen. How can the program do it ?
Then, when on full screen and when I hit ESC to get out of it, on Windows 7, it does not display the actual screen but the previous one. The program is on the actual screen as it responds correctly when I hit any key. It did not do that on Windows XP. How can I get rid of that previous screen on W7 ?
Thanks in advance.
anthonyrichards
New Contributor III
You could try this:
hWnd=GETHWNDQQ(IUNIT) ! Get a Windows handle to the window you want to maximise
iret=SendMessage(hWnd, WM_SYSCOMMAND, SC_MAXIMIZE,0,0)
On Windows 7 64-bit, define hWnd as HANDLE so that it is assigned 8 bytes rather than the default 4 bytes on 32-bit Windows
jmloriot
Hello Anthonyrichards,
I did test the 5 following codes :
iunit = GETACTIVEQQ( )
hWnd=GETHWNDQQ(iunit) ! Get a Windows handle to the window you want to maximise
iret=SendMessage(hWnd, WM_SYSCOMMAND, SC_MAXIMIZE,0)
hWnd=GETHWNDQQ(QWIN$FRAMEWINDOW ) ! Get a Windows handle to the window you want to maximise
hWnd=GETHWNDQQ(0) ! Get a Windows handle to the window you want to maximise
i = INQFOCUSQQ (iunit)
OPEN (UNIT = 10, FILE = 'USER', IOFOCUS = .TRUE.)
iret = SETACTIVEQQ (10)
hWnd=GETHWNDQQ(10) ! Get a Windows handle to the window you want to maximise
The 4 first ones do not seem to have any effect, the 5th one reduces the window to approx. one third of the screen.
Can you help me more ?
Which library can be used to get the handle type ?
Thanks in advance
jmloriot
Thanks in advance
anthonyrichards
New Contributor III
It looks like you have shown that it will only work with the active window.
And probably the window will only maximize within the present size of the frame window, so you need to maximize the frame window first if you want to maximize your child windows within it.
You probably cannot full-screen a quickwin window.
Would building as a "Standard Graphics" application work? This gives you a full screen without a menu.
jmloriot
Yes ! a Standard Graphic application starts on FULL SCREEN (Exactly what I need).
But then the input from the keyboard does not work. I use a function I got from the PeekApp sample :
open(unit, file='user')
do
j = focusqq(unit)
r = incharqq()
call EnterCriticalSection( loc(DrawLock) )
!insert the character
bufput = IAND(bufput + 1,16#000000FF)
if(bufput .eq. bufget) then
CALL BEEPQQ(4000,500)
bufput = IAND(bufput - 1,16#000000FF)
else
buffer(bufput) = r
endif
! release the buffer
call LeaveCriticalSection( loc(DrawLock) )
end do
I guess I have to change the "file='user'" ?
I think so - don't open the unit and just use unit 5.
jmloriot
It does work
Thanks a lot
