29386 Discussions
-gen-interfaces drops Allocatable and Optional (for Types)
Cross__Mat
Hi. I'm using
> ifort --version
ifort (IFORT) 13.0.0 20120731
on
> uname -a
Linux whakarewarewa.nag.co.uk 3.5.3-1.fc17.x86_64 #1 SMP Wed Aug 29 18:46:34 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
The fixes to -gen-interfaces at Version 13 are really appreciated, but there are still some problems.
> cat interface.f90
    Subroutine s(a, b, c, d)
      Implicit None
      Integer, Parameter :: n = 3, k = 8
      Integer, Allocatable :: a
      Type t
      End Type t
      Type (t), Optional :: b
      Integer :: c(n)
      Integer (k) :: d
    End Subroutine s
> ifort -gen-interfaces -c interface.f90 ; cat s__genmod.f90
        !COMPILER-GENERATED INTERFACE MODULE: Thu Sep 13 11:47:10 2012
        MODULE S__genmod
          INTERFACE
            SUBROUTINE S(A,B,C,D)
              TYPE T
              END TYPE T
              INTEGER(KIND=4) :: A
              TYPE (T) :: B
              INTEGER(KIND=4) :: C(3)
              INTEGER(KIND=8) :: D
            END SUBROUTINE S
          END INTERFACE
        END MODULE S__genmod
Note that in the output a is missing Allocatable and b is missing Optional.
As further suggestions, would you consider preserving Parameters in Interfaces instead of semantically replacing them? E.g., preserve c(n) and Integer (Kind=k) :: d in the output?
Cross__Mat
Are there any thoughts here?
TimP
You can't use optional without supplying an explicit interface. Allocatable shouldn't need to be in the interface.
An ALLOCATABLE dummy argument also requires an interface - there is a use for this (when you'll be doing allocation or deallocation in the subroutine) - but most of the time, as Tim suggests, it isn't needed. The .f90 form of the generated interface is just for a human reference - it isn't really intended as a way of creating usable interfaces, though many do. By the time the compiler is generating the interface, all the PARAMETER constant expressions have been resolved. I note that even though the generated interface ,f90 doesn't include OPTIONAL or ALLOCATABLE, the compiler seems to notice it anyway and does the right checking. I will ask that these attributes be included in the .f90 to help users who look at them.
Cross__Mat
Tim: "You can't use optional without supplying an explicit interface. Allocatable shouldn't need to be in the interface." I have explicit interfaces. My toolchain is using ifort to make sure these are always current. The standard says that Allocatable is a dummy's characteristic, so it must be in the Interface if it's in the procedure itself. I'm aware of how to use Allocatable for dummies. Steve: "I will ask that these attributes be included in the .f90 to help users who look at them." Thanks. That will be helpful.
This problem has been fixed for a future major version of the compiler.
