29380 Discussions
generating resource.fd from resource.h
chunky_lover_23
I'm trying to use IVF after years of semi-successfull CVF use.
I've used ResEDIt to edit and generate a dialog reource and have created the resource.h file and the resource.rc file (which compiles ok)
Depite following the "6 steps" rule with deftofd as advised in the help I cannot generate the resource.fd file
Any ideas (i've added the vfproj and build log files) ?
I'm NOT running under ADMIM on a Vista Workstation with the following software
Microsoft Visual Studio 2005
Version 8.0.50727.42 (RTM.050727-4200)
Microsoft .NET Framework
Version 2.0.50727 SP2
Installed Edition: IDE Standard
Intel Visual Fortran Compiler Integration Package ID: w_cprof_p_11.0.072
Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* 2005, 11.0.3453.2005, Copyright (C) 2002-2009 Intel Corporation
* Other names and brands may be claimed as the property of others.
What happens if you manually create a resource.fd file (it can be empty), then modify the rc file? For some reason, it's not running the custom build step to build resource.fd.
chunky_lover_23
the error messages associated with not having the resource.fd file included dissapear and the resource .fd file is updated (good). But the contents of the resource.fd file do not seem correct - specifically there is no reference to the "ok" or "cancel" buttons
integer, parameter :: IDD_DIALOG1 = 100
integer, parameter :: $_WIN32 = 1
character(len=4), parameter :: IDC_STATIC = ("(-1)")
... is this what would be expected based on the .rc file:
// Generated by ResEdit 1.5.4
// Copyright (C) 2006-2010
// http://www.resedit.net
#include
#include
#include
#include "resource.h"
// Dialog resources
LANGUAGE LANG_NEUTRAL, SUBLANG_NEUTRAL
IDD_DIALOG1 DIALOG 0, 0, 186, 95
STYLE DS_3DLOOK | DS_CENTER | DS_MODALFRAME | DS_SHELLFONT | WS_CAPTION | WS_VISIBLE | WS_POPUP | WS_SYSMENU
CAPTION "Dialog"
FONT 8, "Ms Shell Dlg"
DEFPUSHBUTTON "OK", IDOK, 46, 58, 50, 14
PUSHBUTTON "Cancel", IDCANCEL, 128, 58, 50, 14
LTEXT "sfsfsfsf", IDC_STATIC, 23, 17, 22, 8, SS_LEFT
// String Table resources
LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
STRINGTABLE
0 " "
What does the resource.h look like? That's what deftofd looks at.
chunky_lover_23
You're correct - reource.h also did not reference the ok or cancel buttons. Deleting and re-creating these buttons in ResEDIT and re-saving the resource.h file fixed the issue.
Jugoslav_Dujic
Valued Contributor II
If my memory serves me well, IDOK and IDCANCEL are "magic" constants defined in DFWINTY (and somewhere beneath windows.h and should not be redefined in the resource.h file.
