29651 Discussions
generic interface from external procedures
efengle
I am having trouble creating a generic interface.  I have a module that has something like this:
interface do_something
   module procedure do_something_real4
   module procedure do_something_char
end interface do_something
In my source directory, I have separate source files for subroutines do_something_real and do_something_char.  When I compile my library, I get the error #7950: Procedure name in MODULE PROCEDURE statement must be the name of accessible module procedure.
I have tried creating interfaces for these subroutines in the same module source, much like:
interface
   subroutine do_something_real4
   end subroutine do_something_real4
   subroutine do_something_char
   end subroutine do_something_char
end interface
but I still get compiler issues.  Any help is greatly appreciated.
mecej4
Without additional declarations, the "_real4" and "_char" have no meanings yet. The compiler has to have the information necessary to disambiguate the generic name to the specific names based on the types of the variables in the argument list of a subroutine invocation. See examples such as the file ...\mkl\interfaces\blas95\source\blas_interfaces.f90 for guidance. Here is a short extract from that file:
INTERFACE F77_COPY
  PURE SUBROUTINE SCOPY(N,X,INCX,Y,INCY)
    INTEGER, PARAMETER :: WP = KIND(1.0E0)
    REAL(WP), INTENT(IN) :: X(*)
    REAL(WP), INTENT(INOUT) :: Y(*)
    INTEGER, INTENT(IN) :: INCX
    INTEGER, INTENT(IN) :: INCY
    INTEGER, INTENT(IN) :: N
  END SUBROUTINE SCOPY
  PURE SUBROUTINE DCOPY(N,X,INCX,Y,INCY)
    INTEGER, PARAMETER :: WP = KIND(1.0D0)
  END SUBROUTINE DCOPY
As you can see, when the generic name F77_COPY is called, the compiler will use the specific name SCOPY if the second and fourth arguments of single precision real, and will use DCOPY if they are double precision real, etc.
FortranFan
Try this:
module m
   implicit none
   private
   public :: do_something
contains
   subroutine do_something_real4( rval )
      real, intent(in) :: rval
      print *, " rval = ", rval
      return
   subroutine do_something_char( sval )
      character(len=*), intent(in) :: sval
      print *, " sval = ", sval
      return
end module m
program p
   use m, only : do_something
   implicit none
   call do_something( 0.0 )
   call do_something( "foo" )
   stop
end program p
efengle
So all this time I have been having this issue, I was using an older version of ifort (12.1).  I switched over the a more recent version (15.0.1) and issues have been resolved.  Thanks for the help.
