29657 Discussions
generic :: write(formatted) supported ?
Jim_Vickroy
Hello Group,
Below is a code fragment from a module I'm trying to compile withIntel Visual Fortran Composer XE for Windows (just purchased on December 8).
type, public :: Status_Type
contains ! the following type-bound procedures:
procedure :: formatted_unit_WRITE
generic :: write(formatted) => formatted_unit_WRITE
end type Status_Type
Here are the compiler messages:
error #5082: Syntax error, found IDENTIFIER 'FORMATTED' when expecting one of: * .NOT. . + - /) ** / // .LT. < .LE. <= .EQ. == .NE. /= .GT. > ...
error #6268: The keyword ASSIGNMENT or OPERATOR was expected in this context [WRITE]
I'm new to Fortran so there may be syntax errors in the above code fragment. Could someone kindly point me in the right direction. The code fragment is based on an example in a Fortran book (Fortran 95/2003 Explained) I'm reading.
This is a F2003 feature called User-Defined Derived Type I/O. Intel Fortran does not yet support that.
Jim_Vickroy
Amazingly fast response ! Thanks much!
