29627 Discussions
get evaluation version 9.1 for windows
debolina123
Is it possible to download the evaluation version of Intel fortran compiler (IA -32) 9.1 for windows ?
I see that I get the newer version but I would like to tryoutthat older version.
I'm not certain if it's available to you, but it may be. On the Intel Registration Center page describing 10.1.014, about half-way down, should be a set of two dropdown boxes that allow you to change the version to 9.1 and then one of the available updates to 9.1.
It may be that the 9.1 installer does not recognize the evaluation serial number. What you should do is register the serial number at the registration center and ask it to email you the license file. Save that license file to your disk. When you install, select the option saying you have a license file and point the install to it.
