handling 2 dim array
bhpark70rda_go_kr
I have 3 by 3 arrary(xpy).
I want to select (2,1), (3,2) element from the arrary.
I know the position of row and columnas followingrw = (/2, 3/) and cl = (/1,2/).
So I want to select cross point of rw and cl arrays.
How can I select?
Yuan_C_Intel
Do you mean following?
Do i=1, 2
xpy(rw(i), cl(i)) = ...
bhpark70rda_go_kr
Actually, I want to store the result of matrix multiplication into the specific elements of 2 dim array.
for example
I have the result of 2 by 2 matrix and 2 by 1 vector multiplication and want to store it into (2,1) (3,2) of 3 by 3 matrix at one time.
Is it possible?
Jugoslav_Dujic
Valued Contributor II
for example
Is it possible?
No, it's not possible in the single line.
For 1-D case, you may use an index (order) array, for example:
real:: A(5) = (/1., 2., 3., 4., 5.,/)
integer:: iOrder(2) = (/2, 5/)
A(iOrder) = 0. !gives 1, 0, 3, 4, 0
But there's no equivalent construct for 2-D case -- you may not use a 2-d array as an index array. You have to use a DO-loop, as Yolanda outlined.
IanH
Quoting - Jugoslav Dujic
Or, for extra obfuscation points and a possible saving of two keystrokes ;)
FORALL (i=1:2) xpy(rw(i),cl(i)) = the_source(i)
Yuan_C_Intel
Fortran 90/95 (2003 has more extensions)do providea special intrinsic function, callled RESHAPE, that changes the shape of an array,which can initialize a 2-D array in a single assignment, the form of the RESHAPE function is:
output = RESHAPE ( array1, array2)
where array1 contains the data to reshape and array2 is a rank-1 array describing the new shape. The number of elements in array2 is the number of dimensions in the output array, and the value of each element in array2 is the extent of each dimenstion. The number of elements in array 1 must be the same as the number of elements in the shape specified in array2, or the RESHAPE function will fail.
As for bhpark70rda.go.kr's case,we can have:
integer, dimension(3,3):: xpy
xpy = RESHAPE ( /11, *, 31, 12, 22, *, 13, 23, 33/, /3,3/)
Where *are the position of (2,1) (3,2) you put your result into.
