29649 Discussions
having trouble running generic linked list program
Terry_Wong
I have a small test program which creates a generic linked list.   It compiles, but doesn't run.
When I try to access the values of the link, it gets a memory error (access violation).
The values of the list are pointers to unlimited polymorphic variables.
I have attached the code.
Can you tell me what I'm doing wrong?
pbkenned1
Hello Terry,
I think in link.f90, instead of:
  type link
    !private
    class(*), pointer :: value => null()
    type(link), pointer :: next => null()
you should first define 'next' as:
  type link
    !private
    class(link), pointer :: next => null()
Otherwise, you will have conflicting pointer type assignments at line 31 (constructor%next => next) and line 44 ( this%next => next), ie, you would attempting to assign CLASS(link) to TYPE(link).
I made that change, and the code compiled and linked, but the executable crashed at line 56 in link.f90, on the select type:
    subroutine printLink(this)
      implicit none
      class(link) :: this
      select type(v => this%value)
I don't know if this is a compiler bug or not.  I'll need to work through the traceback.  I suspect something funny about line 59:
     type is (character(*))
I think this is legal, but I'll need to look into it.
Thank you,
Patrick
pbkenned1
Hello Terry,
The access violation is due to a bug in link.f90, subroutine printLinks.
On first entry, 'curr' is unassociated.
If you comment out the call to printLink (as shown), the program runs normally.
    subroutine printLinks(this)
    implicit none
    class(link) :: this
    class(link), pointer :: curr
!!!    call printLink(curr)
    curr => this%next
    do while(associated(curr))
      curr => curr%next
    enddo
With that change, things seem normal:
>ifort link.f90 list_0.f90 generic_linklist.f90 -Fe:foo.exe
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.2.176 Build 20140130
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:foo.exe
-subsystem:console
link.obj
list_0.obj
generic_linklist.obj
>foo
           2
           3
           4
           5
           6
           7
           8
           9
          10
   1.230000
 A
 B
Is that the correct output?
Patrick
Terry_Wong
Thanks Patrick, that did fix the problem.
However, I wanted to print the first element as well, so instead of commenting out the first call to printLink, I preceded it with curr=>this, or I could have used printLink(this).
One comment, I can't see the value variable in the debugger.  Is this because it is a unlimited polymorphic variable?
pbkenned1
Hi Terry,
I don't know of a restriction viewing  class(*) variables in the debugger.  Could you be more specific?  For example, using VS2012, in subroutine addInteger(this, value), I set a breakpoint on the allocate statement at line 56:
allocate(v,source=value) !! line 56
With a Debug x64 configuation, I can repeatedly run to that breakpoint and see 'value' updated with every pass:
U506813.exe!LIST_MOD_mp_ADDINTEGER(TYPE(LIST) THIS={...} , INTEGER(4)  VALUE=#00000004 ) Line 56 Unknown
What do you see?
Patrick
Terry_Wong
Yes, I can see the what the variable value contains, but after I allocate v, I cannot see what v contains.
Also, when I am looping through prinkLink, the debugger cannot show me the value of v or this%value.
I am using the debugger in 64 bit mode.
Thanks for looking at it.
Terry
A class(*) variable has no type on its own - you need to be within a SELECT TYPE construct and then a new "copy" of the variable will be visible in the debugger and you can see its contents as if it were the selected type.
pbkenned1
Hi Terry,
Thanks for the feedback.  Right, I can't see the value of the associate-name variable (ie, the 'v') nor the value of this%value in PrintLink().  You might have run into a limitation of the Fortran Expression Evaluator (FEE).  I'll ask the developers.
Patrick
