heap question
tropfen
hello,
i do need an array with the following description:
integer(2) :: iSort(50000000,4,11)
i get the error: catastrophic error: Variable ...iSort too large for NTCOFF. Bigger then 2GB. Use heap instead.
The system is an Win 7 Prof 64bit, the project in an win64-project
In the configuration i have changed:
- fortran/optimisation: heap arrays --> 0
- linker/system: heap reserve size --> 500000000
- alternativly linker/system: heap commit size --> 500000000
The error remains.
What have i done false? What have i missed?
Thanks in advance
Frank
Les_Neilson
Valued Contributor II
You could try making it an allocatable. Les
tropfen
Hello Les, it works. This means that i can adress an array larger then 2GB just by an allocatable array but not with an 'static' array. Is this correct? Even on an 64bit system? Frank
That is correct.
John_Campbell
New Contributor II
Well it mostly works, as demonstrated in the example below: integer(2), allocatable, dimension(:,:,:) :: iSort INTEGER(4) :: I ! ALLOCATE (iSort(50000000,4,11), stat=i) WRITE (*,*) SIZE (ISORT), i write (*,*) 'Expected SIZE = ', 50000000_8 * 4_8 * 11_8 write (*,*) 'GB = ', (50000000.0 * 4.0 * 11.0) * 2. / (2.**30) END
Use: WRITE (*,*) SIZE (ISORT,KIND=8), i instead.
John_Campbell
New Contributor II
Steve, Thanks for the advice. It's good to see a solution is readily available. I should have adopted RTFM. I was expecting SIZE to behave in a similar way to LOC for 64-bit, automatically changing to kind=8. John
SIZE is a standard intrinsic, so its behavior is specified by the standard. LOC is an extension, and we're free to make it do something different.
