29607 Discussions
help the error libsvml.so: cannot open shared object file: No such file or directory
zhizildx
Hi everyone:
I use the intel compiler 10.1, when i compile the model it has a warning:/opt/intel/fce/10.1.018/lib/libimf.so: warning: warning: feupdateenv is not implemented and will always fail. But it has build the .exe sucessfully.
but the exe file deal with the program there is the error :./rams: error while loading shared libraries: libsvml.so: cannot open shared object file: No such file or directory
the include.mk is
#----------------- LINUX Portland Group pgf77/gcc ---------------
CMACH=PC_LINUX1
F_COMP=ifort
F_OPTS=-O2 -pc 64 -free
#F_OPTS=-FR -fp -Vaxlib -save -tpp6 -O3 -w90 -w95 -w -g
C_COMP=gcc
C_OPTS=-O3 -DUNDERSCORE -DLITTLE
LOADER=ifort
LOADER_OPTS=-L/usr/local/NAG/fll6i21dcl/lib -lnag_nag
C_LOADER=gcc
C_LOADER_OPTS=
#LIBS=
LIBS=lsvml -lpthread
MOD_EXT=mod
and the .bashrc
source /opt/intel/idbe/10.1.018/bin/idbvars.sh
source /opt/intel/fce/10.1.018/bin/ifortvars.sh
LD_LIBRARY_PATH=/opt/intel/fce/10.1.018/lib
export LD_LIBRARY_PATH
what is the problem? Could anyone can help me?
