29636 Discussions
help with cpp char* arg passed to fortran function in DLL
bee_o_
In Windows 7 x64 environment. Compiled "W2_model.dll" in Visual Studio 2010 with intel Fortran compiler. "ce_qual_w2" is the "exported" function in "W2_model.dll".  My pointer character argument in cpp is getting corrupted when passed to the Fortran function.  Any help would be greatly appreciated
Problem:  At run time FNAME is corrupted in Fortran function
abbreviated snips from my cpp code:
typedef int  (*W2ADAPTER_CE_QUAL_W2) (char*);
m_hInst = ::AfxLoadLibrary("W2_model.dll");
W2ADAPTER_CE_QUAL_W2   m_ce_qual_w2Fn;
m_ce_qual_w2Fn     = (W2ADAPTER_CE_QUAL_W2)   GetProcAddress(m_hInst,"ce_qual_w2");
char *FNAME="test";
int var = m_ce_qual_w2Fn(FNAME);
abbreviated snips from my Fortran code
INTEGER(4) FUNCTION CE_QUAL_W2 (FNAME)
!DEC$ATTRIBUTES STDCALL      :: ce_qual_w2
!DEC$ ATTRIBUTES DLLEXPORT :: CE_QUAL_W2
 CHARACTER(4) :: FNAME
DIRC = FNAME  ( at run time FNAME = '4   '  when I expect it to be 'test')
  RETURN
END FUNCTION CE_QUAL_W2
mecej4
I think that you have oversimplified the problem. Your Fortran function code does not make much sense. DIRC is default-typed to REAL, the function name is never assigned to, and you assign a character string to a real variable. No Fortran compiler will produce a DLL from this source.
Please construct a complete test problem and repost.
bee_o_
I have solved my problem,  I was missing the following line from my Fortran code.
 !DEC$ATTRIBUTES REFERENCE  :: FNAME
