29389 Discussions
how to check if the array is aligned at 64 byte
Yulong_Ao
I use the directive to align the array at 64 byte, and I want to check whether this works. The following code is my try. However, it is likely that the alignment directive doesn't work because the mod result isn't zero.
program aligntest
       integer ,dimension(9) :: a
       integer ,dimension(9) :: b
       !dir$ attributes align: 64 :: a,b
       a=0
       b=1
       !use the address mod 64*8=512
       print *,mod(loc(a),512)
       print *,mod(loc(b),512)
 end program aligntest
mecej4
You specified that the variables should be aligned to a multiple of 64 bytes. Why, then, do you expect alignment to 512-byte boundaries? Replace 512 by 64 throughout, or vice versa.
mecej4
