how to debug a FORTRAN dll
jd_weeks
I have a C/C++ main program that calls into a FORTRAN dll built in a separate project. I am using Visual Studio 2008 and Intel FORTRAN compiler version 11.0.0.4. I have set the command to start the main program, and it runs just fine. If I try to set a breakpoint in the Fortran code, it turns hollow with a warning badge, and a tool tip that reads, The breakpoint will not be hit. No symbols loaded for this document.
I presume I need to find a symbol definition file (or something) and put it somewhere special. Can anyone help me with this?
I found a posting from Steve from 2003 (!); the answer was "See this" and "this" was a broken link :( A fresh link would be great!
Thanks!
jd_weeks
It turns out I have a different problem- I tried setting a breakpoint on the call into my dll (in the C++ code) and there it tells me "there is no code associated with that line". I just set a breakpoint on another routine defined in my dll, and was able to step directly from the C code into the Fortran. So it's not debugging that's broken, it's getting the code into the dll.
Sorry for the noise!
