29341 Discussions
how to include graphic library in Intel "Use IFQWIN"
iwillflyhighergmail_
Thank you for anyone who can help. I used to compile a project with Compa Fortran, Now I use Intel Fortran instead. Before, it is fine if I "USE DFLIB" to call graphic library, now I have to "USE IFQWIN", however, there are still linking problems shows " unresolved function".
My best guess is that I do not install the QWIN Application in Visual studio 2005. But I can not find where to install it, or may be there are some other possibilities here?
You should have specified the project type as QuickWin when you created the project. But you can fix it up. Change the following project properties:
Fortran > Libraries > Runtime Library > QuickWin
Linker > System > Subsystem > Windows
