how to pass array into subroutine?
Byoungho_Park
Hello
I'm trying to pass the array into subroutine.
Please look at my first program.
program t1
implicit none
integer, dimension(8) :: myarr
myarr = (/1,2,3,4,5,6,7,8/)
call passarr(myarr(5), 4)
contains
subroutine passarr(a,n)
integer, intent(in) :: N
integer, dimension(N), intent(in out) :: A
integer :: i
do i = 1, n
write(*,*) A(i)
end do
end subroutine passarr
end program t1
The results are
5
6
7
8
I want to implement this code for 2 dimensional arrary.
Please look at my second program.
program t2
implicit none
integer, dimension(8,2) :: myarr
integer :: i
myarr = reshape((/1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16/),(/8,2/))
call passarr(myarr(5,:), 4)
contains
integer, dimension(N,2), intent(in out) :: A
write(*,*) ''
do i = 1, n
write(*,*) A(i,:)
end do
end program t2
I hope that the results are
5 13
6 14
7 15
8 16.
However, the result are
5 3616201
13 0
2052332597 2136218672
134253992 201362856.
what is wrong?
Thanks in advance to your advice.
Park
mecej4
In your program T2, you are not passing the intended array section properly. Replace
by
call passarr(myarr(5:,:), 4)
mecej4
by
