how to solve "Stack overflow"
kilby
In my program, large data arrays are frequently used. This time I have to compute the inversion of a 4000 by 4000 matrix, and stack overflow error shows up. The CVF6.5 help documents tell me I should See the Section "Guidelines for Programs That Use Large Data Arrays" in the post-installation part of Compaq Visual Fortran Installing and Getting Started. Unfortunately I can't find it. I have used the /stack:0x5f5e100 compiler option, but it does not work. Any suggestions for the problem? Thanks in advance.
Jian
How are you specifying /stack? From the command line, you'd need to use /link/stack:value after all compiler switches.
You may also find this article helpful.
Steve
