how to use RENAME RENAMEFILEQQ
yjyincj
I tried to use RENAME and RENAMEFILEQQ but failed. My code is pasted bellow. Please help me.
!use RENAME to rename some files
program main
use ifport
use ifcore
implicit none
logical::result,alive
character(len=72)::n,oldname,newname
integer::i,istatus
do i=1,10
select case(i)
case(1:9)
write(n,"('0',I1)") I
case(10:40)
write(n,"(I2)") I
end select
write(oldname,*)'la',trim(n)
write(newname,*)'la',trim(n),'.eq'
!result=renamefileqq(oldname,newname)
inquire(file=oldname,exist=alive)
if(alive==0)then
write(*,*) oldname," does not exist"
exit
end if
istatus=rename(oldname,newname)
!or I use this line instead of the above one
end do
stop
end
Les_Neilson
Valued Contributor II
According to the documentation rename expects a full path.
I replaced your case and internal writes with
write(oldname,'(a,i2.2)') 'la',i
write(newname,'(a,i2.2,a)') 'la',i,'.eq'
and used RenameFileQQ and it worked ok
Les
