how to use Win32 GDI
algraham
I am writing a Windows SDI application in IVF and I would like to use the Win32 GDI graphics routines. However I am unable to find out how to call these routines in Fortransince all of the documentation seems to be in C. Is there a resource out there that documents how to use GDI with Intel Visual Fortran?
The book "Compaq Visual Fortran: A Guide to Creating Windows Applications" is a good reference and applies to Intel Visual Fortran as well.
Jugoslav_Dujic
Valued Contributor II
Xeffort library contains a wrapper module, called XFTGDI, which does most of the boring work (object creation, selection and destruction, coordinate systems conversion) for you. Although Xeffort is a complete framework, you can use only XFTGDI module in your application.
See XeffortLite sample:
href="http://www.xeffort.com/xeffort/samples/samples.htm
and Xeffort documentation and full downloads:
http://www.xeffort.com/xeffort/xeffort_download.htm
Jugoslav
algraham
Thanks foryour help, Steve and Jugoslav.
