29651 Discussions
i am executing bash script on intel parallel studio XE 2017 update 1 linux
Jobin_V_
Starting NMTRAN
 WARNINGS AND ERRORS (IF ANY) FOR PROBLEM    1
 (WARNING  2) NM-TRAN INFERS THAT THE DATA ARE POPULATION.
Building NONMEM Executable
FSUBS.f90(2): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [SIZES]
      USE SIZES, ONLY: DPSIZE
FSUBS.f90(3): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [NMPRD4]
      USE NMPRD4,ONLY: VRBL
FSUBS.f90(6): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE), DIMENSION (:),POINTER ::COM
FSUBS.f90(7): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE), POINTER ::LVS,INT,SLP,AC,LOGIT,A,P,Y,A000035
FSUBS.f90(8): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE), POINTER ::A000039,A000052,A000080,A000079
FSUBS.f90(9): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE), POINTER ::A000051,A000074,A000109,A000112
FSUBS.f90(10): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE), POINTER ::A000111,A000110,A000113
FSUBS.f90(2): error #6580: Name in only-list does not exist.   [DPSIZE]
FSUBS.f90(3): error #6580: Name in only-list does not exist.   [VRBL]
FSUBS.f90(13): error #6406: Conflicting attributes or multiple declaration of name.   [VRBL]
      COM=>VRBL
FSUBS.f90(13): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [VRBL]
      COM=>VRBL
FSUBS.f90(24): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [NMPRD4P]
      USE NMPRD4P
FSUBS.f90(25): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [SIZES]
      USE SIZES,     ONLY: DPSIZE,ISIZE
FSUBS.f90(26): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [PRDIMS]
      USE PRDIMS,    ONLY: GPRD,HPRD,GERD,HERD,GPKD
FSUBS.f90(27): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [NMPRD_REAL]
      USE NMPRD_REAL,ONLY: ETA,EPS
FSUBS.f90(31): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [NMBAYES_REAL]
      USE NMBAYES_REAL, ONLY: LDF
FSUBS.f90(28): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [NMPRD_INT]
      USE NMPRD_INT, ONLY: MSEC=>ISECDER,MFIRST=>IFRSTDER,IFIRSTEM
FSUBS.f90(32): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      IMPLICIT REAL(KIND=DPSIZE) (A-Z)
FSUBS.f90(33): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE) :: DATREC
FSUBS.f90(35): error #6683: A kind type parameter must be a compile-time constant.   [ISIZE]
      INTEGER(KIND=ISIZE) :: ICALL,NEWIND,INDXS
FSUBS.f90(36): error #6683: A kind type parameter must be a compile-time constant.   [DPSIZE]
      REAL(KIND=DPSIZE) :: G(GPRD,*),H(HPRD,*)
FSUBS.f90(38): error #6683: A kind type parameter must be a compile-time constant.   [ISIZE]
      INTEGER(KIND=ISIZE) :: FIRSTEM
FSUBS.f90(39): error #6406: Conflicting attributes or multiple declaration of name.   [IFIRSTEM]
      FIRSTEM=IFIRSTEM
FSUBS.f90(60): error #6410: This name has not been declared as an array or a function.   [ETA]
      INT=THETA(001)+ETA(001)
FSUBS.f90(115): error #6498: The use-name for this local-name is not defined.   [MSEC]
      IF (MSEC == 1) THEN
FSUBS.f90(25): error #6580: Name in only-list does not exist.   [DPSIZE]
FSUBS.f90(25): error #6580: Name in only-list does not exist.   [ISIZE]
FSUBS.f90(36): error #6279: A specification expression object must be a dummy argument, a COMMON block object, or an object accessible through host or use association.   [GPRD]
FSUBS.f90(26): error #6580: Name in only-list does not exist.   [GPRD]
FSUBS.f90(36): error #6279: A specification expression object must be a dummy argument, a COMMON block object, or an object accessible through host or use association.   [HPRD]
FSUBS.f90(213): catastrophic error: Too many errors, exiting
compilation aborted for FSUBS.f90 (code 1)
No nonmem execution.
[root@NIBC2319 ~]# ifort -v
ifort version 17.0.1
gcc version 6.3.1 20161221 (Red Hat 6.3.1-1)
let me know if you need any other details.
jimdempseyatthecove
Is self explanatory.
SIZES.mod is apparently a module of your's or 3rd party. It is either missing or it's path is not in your INCLUDE path.
If SIZES.f90 is one of your sources, then assure that NMTRAN.f90 is dependent on SIZES.mod (and that the output of the build of SIZES.mod is placed into the expected folder).
Jim Dempsey
Jobin_V_
it working now...thanks
i did nothing i just re run the script from the beganing.
jimdempseyatthecove
This is generally indicative that your make file is not specifying the dependencies correctly.
I suspect that you may be compiling the .f90 sources that produce the modules (.mod) together with the .f90 sources that USE the modules. To correct this, split the compiler command(s) in the make file such that the USE-ers are dependent upon the modules (.mod).
Jim Dempsey
