idb cannot find Library
Boris_B_
My Fortran program uses Lapack:
$ ifort -r8 -c -g prog.f sub.f
$ ifort -r8 -g prog.o sub.o -lmkl_lapack -lmkl_ia32 -lguide
$ a.out
runs just fine, and so does
$ gdb a.out
(gdb) run
but
$ idb a.out
(idb) run
bombs with message:
dyld: Library not loaded: libguide.dylib
Referenced from: a.out
Reason: image not found
Please help.
TimP
libguide should be found if you have set the ifort environment variables. In general, foridb, you would need to set both the idb and the compiler environment (e.g.by idbvars and ifortvars scripts). Perhaps your environment variables have become unset since you ran the first cases successfully.
Boris_B_
Thank you. I had run ifortvars but not the idbvars. Running idbvars solved the problem.
