ifc 8.1: g++ error
parmenide
when trying to run intel fortran compiler version
8.1, I get the following error message:
ifort: error: could not find directory in which g++ resides
However, g++ IS installed.
How could I solve the problem ?
What g++ files is the Fortran compiler looking for ?
Thank youhttp://softwareforums.intel.com/ids/board/post?board.id=11#
TimP
The installation script should be looking, running as root, for the first g++ installation on the path. It must be gcc-3.[234].x. If you su before running the installation script, 'which g++' should indicate which one will be found. Provision for the directory structure of gcc-3.4 is new in icc. I don't believe it will work with gcc versions outside the range I mentioned.
The script probably runs g++ --print-search-directories to figure out the library and include paths required to support -cxxlib-gcc as the default STL option. If this doesn't succeed, it should set up -cxxlib-icc (Dinkumware STL) as its default.
higamasa
Thank you
Check the environment variable LANG and unset it if it is set.
At the first time I used ifort 8.1, I got the same message even though I have g++ 3.3.2 on my machine.
$ LANG=fr_FR.ISO-8859-1 ifort xxx.f90
$ LANG= ifort xxx.f90
$ ls
a.out xxx.f90
I hope it will be of help.
Message Edited by higamasa on 09-18-2004 07:55 AM
sugimoto605
Message Edited by [email protected] on 09-22-2004 08:22 AM
sugimoto605
Engineering is aware of this problem and is working on a solution. I would advise anyone who runs into this to contact Intel Premier Support about it.
maurice_libes
I think you have to specify where are the new intel fortran libraries
if ifc8.1 resides in /opt/intel_fc_80/ and thus the libs in /opt/intel_fc_80/ lib
edit your /etc/ld.so.conf file
and add
/opt/intel_fc_80/lib
:wq
dont forget to dynamically configure your linker run-time bindings
$ ldconfig -v
it worked for me
alpaz78
hi!
I already tried all of the approaches listed below and nothing works. I'm still having the same problem . . .
I'll appreciate any help
Alex
alpaz78
hi!
I already tried all of the approaches listed ABOVE and nothing works. I'm still having the same problem . . .
Alexander Paz
Message Edited by alpaz78 on 03-20-2005 03:38 PM
Please contact Intel Premier Support - they can help you with this.
