I posted time ago a little code which showed a bug in I/O with large files.
Now that problem is solved.
I slightly modified the code in the following version
program prova
implicit none
real(8),dimension(10000) :: vettore=1.d0
integer :: max_value=5000
integer :: i,j
do j=1,5
write(*,*) 10000*10**j/1024./1024.*8,'MB'
open(unit=10,file="prova.bin",form="unformatted",action="write")
do i=1,10**j
write(10) vettore(1:max_value)
end do
close(10)
open(unit=10,file="prova.bin",form="unformatted",action="read")
do i=1,10**j
read(10) vettore(1:max_value)
end do
close(10)
end do
end program prova
Apparently it segfaults at line
and it appears to me that the problem is related to the use of parts of arrays in the write statements (simply writing the whole vector is ok).
ifc 8 with latest patch (Intel Fortran Compiler for 32-bit applications, Version 8.0 Build 20040211Z Package ID: l_fc_pc_8.0.039_pe042) on RedHat 9.
Can anyone check this code?
program prova
implicit none
integer :: i,j
do j=1,5
do i=1,10**j
end do
close(10)
do i=1,10**j
end do
close(10)
end do
end program prova
