29657 Discussions
ifort 11.1 and O2 optimization: wrong results
Pierre_T_
Dear all,
The code in question:
! MODULE FOR TYPES
MODULE mod_types
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: type_glob, type_geom, type_edge
  ! Type node
  TYPE type_node
     REAL :: X = 0.D0
     REAL :: Y = 0.D0
  END type type_node
  ! Type edge
  TYPE type_edge
     TYPE(type_node) :: node1
     TYPE(type_node) :: node2
     REAL :: Len = 0.D0
  END type type_edge
  ! Type geom
  TYPE type_geom
     TYPE(type_edge), POINTER, DIMENSION(:) :: tabEdge => NULL()
  END type type_geom
  ! Type glob
  TYPE type_glob
     INTEGER :: nbBody = 0
     TYPE(type_geom), POINTER, DIMENSION(:) :: geom => NULL()
  END type type_glob
END MODULE mod_types
! MODULE FOR ROUTINES
MODULE mod_sub
  USE mod_types , ONLY : type_glob, type_geom, type_edge
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: sub
CONTAINS
  ! Subroutine sub
  SUBROUTINE sub(glob)
    TYPE(type_glob), POINTER :: glob
    CALL lire(glob)
    CALL lire2(glob)        ! Good results when commented. Bad results when not commented
  END SUBROUTINE sub
  ! Subroutine lire
  SUBROUTINE lire(glob)
    TYPE(type_geom), POINTER :: geom => NULL()
    TYPE(type_edge), POINTER, DIMENSION(:) :: tab => NULL()
    INTEGER :: ibody, N, i
    N = 128
    DO ibody=1, glob%nbBody
       geom => glob%geom(ibody)
       ALLOCATE(geom%tabEdge(N))
       tab => geom%tabEdge
       DO i=1, N
          tab(i)%node1%X = 1.D0
          tab(i)%node1%Y = 2.D0
          tab(i)%node2%X = 3.D0
          tab(i)%node2%Y = 4.D0
          tab(i)%Len = SQRT( &
               (tab(i)%node1%X-tab(i)%node2%X)*(tab(i)%node1%X-tab(i)%node2%X) + &
               (tab(i)%node1%Y-tab(i)%node2%Y)*(tab(i)%node1%Y-tab(i)%node2%Y))
       END DO
       DO i=1, N
          WRITE(*,'(A9,5E20.12)') 'output = ', &
               glob%geom(ibody)%tabEdge(i)%node1%X, &
               glob%geom(ibody)%tabEdge(i)%node1%Y, &
               glob%geom(ibody)%tabEdge(i)%node2%X, &
               glob%geom(ibody)%tabEdge(i)%node2%Y, &
               glob%geom(ibody)%tabEdge(i)%Len
       END DO
    END DO
    tab => NULL()
    geom => NULL()
  END SUBROUTINE lire
  ! Subroutine lire2
  SUBROUTINE lire2(glob)
    WRITE(*,*) 'hello'
  END SUBROUTINE lire2
END MODULE mod_sub
! MAIN PROGRAM
PROGRAM main
  USE mod_sub , ONLY : sub
  IMPLICIT NONE
  TYPE(type_glob), POINTER :: glob => NULL()
  INTEGER :: i
  ALLOCATE(glob)
  glob%nbBody = 1
  ALLOCATE(glob%geom(glob%nbBody))
  CALL sub(glob)
  DO i=1,glob%nbBody
     DEALLOCATE(glob%geom(i)%tabEdge)
  END DO
  DEALLOCATE(glob%geom)
  DEALLOCATE(glob)
END PROGRAM main
Wrong results (at line 113: output = ) appear when line 76 (CALL lire2(glob)) is not commented. Good results appear when this line is commented. Good result is sqrt(8)=2.8284
Problems appear with ifort 11.1 20100806 and the O2 optimization. No problem with O0 optimization. No problem with ifort 13.1 (even with O2)
It seems that when tab(i)%Len is computed, values for tab(i)%node1%Y and tab(i)%node2%Y are not the ones read just the lines before but the ones given at initialization (here 0.D0)
Any idea ?
Thank you.
Pierre
Use the newer compiler. Bugs get fixed. 14.0 is current.
Martyn_C_Intel
Otherwise, if you need to use the 11.1 compiler, try to identify which routine needs to be compiled with lower optimization, (e.g. using a binary search). Compile just this at the highest level that gives correct results. For example, you might try -O1, or -O2 -fp-model precise.
